Well I tried to start my mercruiser but no turnover just a click, I noticed a exposed red wire dont know where it goes it looks like it coming out of wiring harness, I will add a picture, please can someone tell me some good news...
The 898 (305) came in two wiring types BIA and non-BIA color coding. Looking at the wire going from the starter solenoid to the starter is it Yellow (non-BIA) or Yellow/Red (yellow with red stripe and BIA)
have you owned the boat for a long time, or is it new to you?
why is there a wire-nut on the wire?
what is the battery voltage under load - have you had the battery tested?
are all the connections between the battery and the starter/block in good clean condition. by clean, I mean shiny and clean enough your wife would eat off them.
You dont give much info to go on, was it iwinterized, has it been running, is this the first start of the season,and drive service, etc?
Could be from a isolator system since removed and put back to the standard Orange wire but per Bondo that a alt pic not a starter
