Hello all, thought I’d make it through the whole season without any major issues. I was sadly wrong.
This past weekend I went to start the boat and it wasn’t starting like it normally would, the starter sounds like it engages for about one second and then just spins. Ended up taking off the power steering belt and it fired up.
Then once I had idled out of the no wake zone and tried to bring it up on plane it bogs down and will stall out if I don’t back off the throttle. If I put it in neutral and throttle only it will go full rpm, but under load it will bog down and eventually stall.
It will then not start unless you allow it to sit for a little while. So I pulled it out of the water and checked the usual suspects.
I replaced the fuel filter, spark plugs (all of which on starboard side were badly fouled, port side looked clean), did an oil change, and checked the filter before the carb which was clean.
Now it starts up pretty easily ( I think the starter may still be bad). But it still won’t go WoT. You can’t even slowly ease it up on plane.
I’m not sure what the next steps should be, it appears to have enough gas going into the carb, but possibly a bad fuel pump? Or maybe something with the distributor? Gas in the tank is clean and fresh.
