1985, 85 hp force no power under a load
jagman
hi and i hope somebody can help.i have changed fuel,hoses,had carbs rebuilt it will run great for<br />10:00 min then fall on its face no power under a load idles fine comp. on all 3 is 125psi also i did put a new impelleron because the alarm did go off buti turned it off right a way.forgot to tell you that the insulation from the hood fell apart and thats why i had the carbs. rebuilt<br />let me know if you can help
