jgelsthorpe
- Jul 3, 2011
- 24
i have a 1985 85 hp force and when i start it in a bucket at a idle no water comes out two holes . but when i put in lake . there is a hard spray and hot too. but no buzzer and runs fine , but when wot for about 30 sec. buzzer goes off and then put in neutral buzzer goes off . but the thing that is not normal to me is this hard spray and hot to touch. but after watching videos on this motor almost all the discharge water comes out exhust above prop. so checked thermo stat in a pan of water and it opened but not 110 degrees , maybe around 150-160 degrees. so i planed on changing that but i have feeling that is not the problem also cleaned carbs thinking maybe plugged jet and running lean on a cylinder at wot and then getting . but that don't explan hard discharge out the two holes on back of motor instead of going out exhaust. any thoughts ? Is the a hose that runs out exhust maybe plugged up. thanks . josh gelsthorpe
