1985 - 85HP Force Lower Leaking Gear Oil
tuitelee
Hello, I have a 85HP that is leaking gear oil through the single port exhust. Can someone tell me what I should do?
Walker
Re: 1985 - 85HP Force Lower Leaking Gear Oil
First question. Are you sure it's gear oil. A lot of outboards will drip black, cruddy, fuel/oil mixture.
fishthebay
Correct. It is unburned fuel. Mine does the same thing and lots of it.<br /><br />What kind of 2 stroke oil are you using in your mix?
