Hi guys! I just bought this boat and the guy I bought it from told me the tilt motor was bad. I replaced the tilt motor and it still won't tilt down. I tested voltage at the motor and I was getting battery power on the up wire but not the down side. I switched the solenoids and tested and I had voltage on the down wire and nothing on the up wire. So I know I need one solenoid, but just to test I hooked it back up the tilt still didn't work. It makes a click noise but that's it. Do both solenoids need to be working in order for it to work at all? Or can something else be wrong?
