1985 Johnson 140hp 2 stroke - no electrical power
louisorr123
G'day!
My 1985 johnson 140hp 2 stroke outboard is having some electrical issues that are quite difficult to describe but I will try make an effort to explain it as simple as possible...
Basically, the engine does not seem to be reacting to the ignition being switched on - at least most of the time. Every now and then while I'm playing around with the engine trying to work out what's wrong, it will spring to life, in that the analogue volt meter on the dash will bounce up to 12.8V and it appears that everything is fine, however, this may only last momentarily OR if i try start the engine or use the trim switch, it will instantly lose all power and the volt meter bounces back down to 0. When I do try start it, if I'm lucky enough to have the engine react to the ignition being switched on, I hear a loud spark come from the outboard and all power is again lost.
I'm inclined to assume that this is an electrical short but for the life of me I have not been able to figure out what is causing it! Any help would be greatly appreciated, I understand my explanation of the problem isn't very detailed but it's very hard to explain as there is no apparent pattern as to when the motor will or won't react to the ignition being switched on.
Thanks!!
PS, I have tested both the starter and solenoid and they both work fine.
Bosunsmate
check all your wiring for frays that will be shorting to ground.
and clean all your ground wire bolts/areas where they ground
louisorr123
Just sorted it. Needed to clean the battery terminals, feel like an idiot. Thanks for the help!
