1985 Mercruiser 170./470
stacymd
My mechanic has this running great now. Had issues last year with starting. Replaced the starter and also replaced internal charging system with alternator....However, after running on the water for about 30 mins, the engine will start running rough, lose rpms, then speed up , slow down. Could not get more than 2800RPM's..After it cools down runs fine..THen same thing after it warms up. New point, condenser, etc for the season. Pulled the tachometer wire and still the same issue..IS it possible the coil is breaking down and causing a firing problem...DOes not seem like a fuel problem...Even would back fire at times...ANY IDEAS?
karayj
Re: 1985 Mercruiser 170./470
I had the same problem go to you auto parts store and get a coil for 20.00 see if its that if it is then go get a marine coil after its better then spending 50.00 for a coil and then finding out it was not the coil but i bet its the coil
stacymd
thanks....I should know tomorrow when I take her out. We seem to think coil as well...thanks....
stacymd
HAd the boat out today...The new coil did the trick. No more funkiness. Had the best time since buying this boat. Hope it continues to run this good...Alternator upgrade was one of the best things I have done.
falcon50
Stacymd,<br /> Can you give me any information on the alternator upgrade? I wanted to do this over the winter on my 470 but don't know where to get.<br />Thanks,<br />Bill
