1985 Monark Center Console
sersama123
Hey all, I recently bought an 85' Monark. After a couple weeks of work it was ready to get water tested. So I took it down to the water, not 5 minutes had passed and the boat was taking in massive amounts of water (thankfully I still had it hooked up). It's my understanding that I only needed to plug the main drain, obviously not for this boat. Can someone that has experienced this problem with this type of boat tell me what other holes need to be plugged? thanks.
southkogs
Can you tell where the water was coming from? If you have more ports below the waterline, then maybe one of those is letting water in. After that, you kinda' have to get your head in there and see where the water is coming from.
Sorry you're having the troubles, but welcome aboard.
