1986 Bayliner 225E (305) Engine/275 Outdrive
macrae
The last time I was at the lake, I put the boat into reverse and gassed it a little and the outdrive came up out of the water. This boat year and outdrive did not have trim, only full up and full down. Can somebody identify with this issue and how to correct? Thank You
jerryjerry05
What drive?
The 275,280 or 290??
There was different lift systems for the drives?????
jerryjerry05
Was that 275 there before??
Sorry I guess I didn't see it.
The 275 doesn't have a trim only a tilt function.
The tilt can be used but only at slow speeds.
The drive popping up is a lockdown malfunction.
Could be worn latches or broken springs or just corroded??
Not cheap either.
