Motor set awhile and I rebuild carbs, new plugs, decarb, and water pump. When you first start the motor it will run great and get up on plane fast then you get a quick beep then it goes to safe mode. I think it is a oil problem. Oil tank is full of new oil but was wondering what is the most common cause of oil restriction on this motor. Also what type of 2 stroke oil is the best if you cannot get suzuki oil. I noticed a inline oil filter on the motor how often do they get plugged up. What is the best way to trouble shoot a oil restriction.
Also how do you bypass the oil sensor on the top of the oil tank.
Thanks
Thanks
