1986 Mercury 200 h.p. knocking sound
imabrewer
I just took my 200 h.p. Mercury 6-cylinder (no EFI) out for the first time this year since having my dealer winterize it last October. The motor fired right up and ran great in idle. After I cleared the harbor and hit it full throttle, a noticeably loud rattling / knocking noise came from the engine above 3000 rpm that sounded like a bolt was banging around in the flywheel housing. I thought that maybe a spark plug wire was loose from the winterizing, but everything looks good. The motor was running great when I had it winterized, now it's making this odd noise but still runs seemingly well. It seems like the knocking lessened after I had run about 20 gallons of fuel out (I know, I was stupid to keep running it), but maybe I'm just wishfully thinking that I won't have to spend $3,000 for an engine repair! My dealer says it sounds like something loose inside the motor (bad bearing maybe) and wants to tear the engine apart to inspect it. I am thinking it might just be bad fuel if they didn't stabiilize it correctly. I pre-mix my fuel in the tank since my oil injector was removed by the previous owner years ago. Should I try fresh fuel before I let the mechanic tear my motor apart? As a side note, I had added a fuel flowmeter to the fuel line over the winter, would a lack of fuel flow be causing this knocking sound? I've also noticed that when in idle, my fuel line slowly drains back to the tank and kills the motor after a few minutes, almost like I have a loss of suction from the motor. I've replaced all fuel lines, bulbs, filter etc. up to the motor but haven't replaced anything in the motor yet. Again, would a fuel loss issue be causing the knocking as well? Grasping for straws now, but I trust someone here can set me straight and tell me the really bad news. Thanks!
Chris1956
Re: 1986 Mercury 200 h.p. knocking sound
Curtis, It sounds like your motor is experiencing pinging or detonation at high RPM. You need to fix this issue. Pinging is caused by low octane fuel or incorrect spark timing (too advanced). Detonation is usually caused by a too lean mixture. Since your fuel is likely malfunctioning, I recommend you rebuild it. This may solve the problem. <br /><br />PS both pinging and detonation will destroy your motor in time.
kell490
That is the same exact problem I just had. The only thing I did different then I normally do is runned 87oct instead of 91 from the gas station. The lake pumps only have 87 so I figured with gas prices as they are Ill use 87 from the gas station my manual says to use 87. The boat is in the shop now. I have a 96 merc 200 EFI. Could this be caused by 87oct gas? I ran all day pulling a knee board didn't have any problems till the end of the end of the day when we were the farthest from the ramp.
KCLOST
Man, this could be a bunch of things....<br /><br />First, <br />Did you forget to pre-mix lately?<br />Have you taken the cover off and tried to listen for the rattle?<br />Have you checked compression?<br />Have you checked spark on all cylinder?<br />Try different fuel, with a new line (get rid of the fuel meter for a while). It may be running lean....
2springers26
if you feel It's a rod bearing issue... Pull the heads & rotate the fly wheel.. & watch the pistons... when you change dirrection of rotation watch the pistons NOT @ top dead center or bottom dead center,,,,, the piston shold move instantaniously with the dirrection change.... fi you feel you have a detonation knock... run higher octane fuel....
