1986 Mercury 90HP Not firing on 2,4,6.
dawg_nail
After doing some investigating on why my Merc would bog down in the water I found that cylinders 2,4, and 6 aren't firing. Does this mean that the switch box is bad or could another problem exist>
S.T. Marine
Re: 1986 Mercury 90HP Not firing on 2,4,6.
I would assume one of your switch boxes is bad. To determine that switch the wires on each box anotherwards switch boxes to make sure its the box. That will tell you whats the problem good luck
