1987-125hp force seems to bog down some.
mick97
Hi everyone.
I took the kid out tubing the other day,and seems to bog down on turns.. Seems to go ok straight ahead,and i know turns can slow it down,but seems to bog down.. Starts hard,and dies unless i put it in gear right away,alot too. Going full speed is ok for awhile,then i have to let up on the throttle a tad..
I did a carb clean,and new plugs,and no difference.
Could it be timing?Where is the timing screw? On top of one of the carbs?
Seems 1/2 throttle it runs pretty smooth..
Any ideas?
Thanks everyone :)
jerryjerry05
Timing: IF??? nobody has touched it?? then it shouldn't need adjustment.
Do a compression and a spark test.
Post the results.
Check the overheat system and see if it's working?? sounds like it might be getting hot?
Bogging on turns: when starting the turn lower the drive to compensate for lost forward thrust.
The screws on the carb are NOT timing screws.
They are air/fuel mixture screws.
They control the a/f mix at idle.
If you haven't touched them? then leave them alone.
1 screw out of adjustment can lead to engine failure.
Get a manual, read the top posts in this forum for tips on doing things to improve the performance.
Check the fuel for water?
