Hi i have a 87 force 125 outboard and i cant find the problem. when i put it in forward and hit the throttle the motor will jumo and skip like it is jumping in and out of gear or jumping a tooth on a gear. it will idle fine and run good at low rpm but when the throttle is pushed down and there is a load on the motor it starts to jump, shaking the whole boat. i replaced cdi modules, coils, and flywheel, pretty much ruled out miss firing. timing is back it order too. last night i took the prop off to check the teeth on the prop and the shaft for the prop. both were fine and showed no sign of and slippage or jumping. so i out back on and put the boat in the water but left it on the trailer. put it in gear and the same problem, so i put it in full reverse and no signs of anything wrong no jumping or anything. ive done research and the only thing i found was maybe the clutch dogs, is there a way to test these, any help would be greatly apearciated !!
thanks alot!!
thanks alot!!
