Hi, I have a 1987 force that has had a lot of issues in the past few years. I started the motor up 2 weeks ago and noticed a lot of gas running down the lower unit out of a small hole behind one of the lower unit bolts. It was also running out of the exhaust port above the propeller. After running the engine, I removed both of the spark plugs and saw the top cylinder plug was completely clean and had fuel inside. The bottom plug was burning chocolate like it is supposed to. If the cylinder is not firing, could this cause the piston to push out unburned fuel? The carberator is fine as well as compression. Both plugs also have equal spark. Does anyone have an idea of what might be causing this? Any suggestions will be appreciated. Thanks.
