1987 johnson 120 cutting out higher rpm
garster59
this engine is cutting out at higher rpms and when it happins it is very instant ignition failure and as soon as i pull back on the gas it catches agin. i have inspected the ignition plate under the flywheel and did not find any broken wires. i also cannot duplicate the problem because it happen only 3 or 4 times a year.. can any body help...
Bob_VT
Re: 1987 johnson 120 cutting out higher rpm
Open your throttle control box and look for a loose wire.<br /><br />Bob
