I recently purchased a boat with a 175hp. When I take the boat out, after about 5 minutes of run time at 3000 to 4000 rpm the warning horn goes off. I shut the boat down and right away I can restart the motor and go again for another 5 minutes or so. The horn doesn't go off at trolling speed and doesn't go off all the time. Water flow from pee hole is a solid stream. Is the problem a sensor or a short in the wiring?
