Smokey Edwards
- Jul 4, 2020
- 11
I have a boat that has a mostly rotted floor that I have removed. I am experienced with fiberglass. So it would not be too much for me to do... But I can not get the motor to turn over. It has been sitting for about 8 years. I hear a click in the starter solenoid but wonder if and how to get the motor to rotate. I have a fresh battery in it. Was thinking of adding a 200 more amps with a starter boost.
I am just trying to verify if it rotates. What to do at this point? I also can not get the tilt to operate. That too has a solenoid click. but that is it.
I have everything hooked up. Would like to verify this before motor removal before floor repair. May not want to do job if it becomes to detailed. If I remove the motor to a stand to get at it, should I also remove the harness and console?
What do you guys do to get your engines to rotate if stuck? I was told that it was winterized before being put into storage by a friend who previously owned it. What problems should I expect?
Thanks, I need some help to make better decisions about if I should even try.
Also wondering what other engines might hook up to the intermediary housing.
