1988 120 johnson no voltage to purple wire on alarm.
gmortie3rd
Wondering what could be at fault.
No voltage at purple wire and low voltage on brown wire at alarm when grounded.
Also how many volts should be going to vro no oil sensor??
Thanks!
saltchuckmatt
Didn't answer post 2. I believe the purple wire hooks to ground on the horn. Horn is polarity protected. Test the horn to 12 volts.
saltchuckmatt
No I'm wrong, purple is positive but key needs to be on and in neutral maybe. Now I'm brain farting.
saltchuckmatt
Post model number. Nevermind, do not need it.
You should have hot to purple if grounded correctly. If your trying to go through the horn and it's defective than that's your problem otherwise you have a wire or corrosion issue.
gmortie3rd
Horn is burnt out. Horn was removed when testing. Brown wire to ground was 4v i think? And purple to ground was 0.
Note i had the wires on the port side temp senspr switched for a bit after replacing computer. Could this have fried that circut that feeds the purple wire? Or is there another common cause?
saltchuckmatt
On your tester....where did you hook up your ground? The brown wire? If so, ground to the battery and turn the key on and test the purple wire. If there is no power replace key switch.
gmortie3rd
Black was to was to ground. I have a good ground to the hull.
