1988 Bayliner OMC starting/fuel issue
Caycer
I have a 3.0 OMC on my Bayliner. i have had it out running on the river and it has started bogging down while under way. The first time it did it, i thought fuel. I took all the fuel out and filled up the tank with new. I changed the anti-siphon valve, fuel filter in the pump, and the little filter before the carb. Took it out on the water and ran it for an hour or so at various speeds. We parked on a beach and the kids played for about 30 minutes. Got back in and it wouldn’t start. It turned over fine and it tried to start, but died. It took about 15 key cycles and it finally started. We got underway and I was able to get it up on plane and to about 25mph. At WOT the RPMs didn’t go over 2500. Book says it’s supposed to be hitting 4500. While underway for 15 min, the engine just all of a sudden started dying, then quit. After a few tries it restarted and we made it back to the launch and trailered it. Brought it home and it sat for a week without starting. Took it out to the river yesterday, backed it in and it would not start. When you turn the key, it fires up and then immediately dies. Took off the flame arrestor, used starting fluid and it would not start. Took off the linkage cable and manually moved the accelerator and 2 streams of gas shot into the carb. I played with the choke in various positions with nothing helping. I held the accelerator to the floor and it started, revved really high, then died. Nothing i did worked. I checked the shifter position, the operator kill switch, but that is all i could think of. Help please!!!
southkogs
How's the spark? Are spark plugs fouled, wires good, getting good hits on all cylinders?
Lou C
These older OMCs have a points and condenser ignition system that needs regular maintenance to be reliable. Your problem does not appear to be fuel related so you need to check out the ignition system.
kenny nunez
In addition to the previous posts which you need to follow. Make sure that the points and condenser are genuine replacements from either an OMC dealer or at least a NAPA store. After it gets back to running connect a volt meter to the + side of the coil and watch for at least 8-9 volts, there is a possibility that the resistor wire in the harness could be causing the problem also.
jerryjerry05
Another thing, the fuel pump, the pump has a filter inside.
Big rock type filter. Gets clogged and allows some fuel but then cuts off as you go faster.
