1988 Crusader 270 thermostat question
jif102
I have a 1988 Silverton 30X with twin crusader 270 inboards. The previous owner had a 140 degree thermostat and a 160 degree thermostat in the motors. What is the correct temperature rating for the thermostats? I removed them for winterization and will replace them over the winter and want to order the proper one.
thanks
Ayuh,.... Raw water cooled,..??
Saltwater, or Sweetwater,..??
I run a 160? in mine, boatin' on the Sweetwater seas,.....
Ayuh,.... Higher heat is more fuel efficient, the reason for runnin' Cold, is salt contamination,...
