1988 dt85 popping sound while running
so
Finally got her up and running, starts up every time if i open the throttle slightly but seems to be some popping sound? kind of like a fire cracker. Video is here
. you can hear it every now and then (i.e, at 0:27 and 0:30 mark) particularly towards the end. is that a knock?
For context; this is a continuation of my other post, https://forums.iboats.com/threads/low-compression-2-cylinder-1988-suzuki-dt85.763393.
Cylinder has low compression (40 psi), planning to do a powerhead swap.
so
So is this the "new" powerhead, or the original one?
original. i wanted to make sure it can fire up before buying one. everything is original except the carb gaskets, fuel hoses and plugs.
Faztbullet
Hard to tell as not backpressure on engine...exhaust pop could be backfire in exhaust tube.
QBhoy
Just sounds to me like an engine running dry and not running on all its cylinders or with a compromised compression and/or ignition system.
