1988 Force 125 hp controller
Casnart80
What controller do I need for a 1988 Farce 125Hp engine? I'm installing the engine on an old pontoon project I've been messing with. I have a Mercury, standard block box like you see everywhere. Will this box work for the Force 125 Hp engine? I know I have to change cables, but it seems the throttle works backwards to the Mercury control box I have.
jkoppen73
On my 1986 85 h.p., I replaced the original with the UFLEX B184 and it works fine. It has wiring/switch for tilt/trim built into the unit. Two yr. warranty. Not sure but I think I got it on flea bay...
jerryjerry05
Any Force/Chrysler shifter up to 95 should work.
If you need the key switch and T@T your best bet is new.
But!! ebay sometimes has what you need?
264356132515 $65
jerryjerry05
Oh yea that Mercury shifter probably won't work unless you get the shift parts off of a
95+ Force
But that might not work either :(
