Re: 1988 Force 50 hp Sparking on only 1cylender
The Clymer Manual goes into detail of how to diagnose each component.You'll need a volt meter capable of reading 600VAC. Instead of going by the values in the book,which are given as "DVA", use a standard meter set to the AC auto-range, If you get a reading that is ballpark, you can scratch that component off the replacement list.<br />To list the entire procedure here would activate my carpal into tunneling, as it is 4 seperate pages of typing outta the book.<br />Another good argument for the purchase of a manual,is even after it has saved you buying stuff you don't need, it can tell you how to keep your engine frosty,and in reliable condition.
