1988 Mercruiser 165 stalls when shifting
pegsyg
I have a 1988 Mercruiser 165 that is giving me fits. It is very difficult to start and once I get it started it will stall when shifting into forward or reverse. As well as sometimes when I shift to neutral. I have replaced the plugs, rotary button and Dist. Cap. When attempting to start the engine sounds great but it will not start. I am at a loss. I cannot figure out what is going on. Also, can anyone tell me the RPM specs at idle and while in gear?
Fouled Plug
Ensign
Re: 1988 Mercruiser 165 stalls when shifting
Is the choke operating properly? What are your current RPM's in gear/nuetral?
iwldntli2u
I would agree check your choke. If the RPMS are running low turn the idle screw up a bit but not to much, You do not want to grind it in grear.<br />Good Luck!
record hunter
I sugest checking your points that engine should start right up. I changed to electronic points.Its easy to change and you dont have to worry after that. Check your timing also it is prob off I dont even use my choke I have it wired open and get better gas mileage. But I live in a warm climate. Your shifting problems are prob your netural safety switch check that. If your linkage is not adjusted p erfectly that will happen it did for me atleast You should have a manual and read up on it
Mikedg
The shift interupter switch may need adjustment along with the idle. When you shift from neutral into gear a micro switch kills the ignition for a moment allowing for a smoother shift with less impact on the drive.
