I have a 1988 four winns 180 horizon with a 4.3L OMC Cobra outdrive. When out of the water the prop spins fine, once in the water the boat idles around easy but will not speed up. Just changed the hub in the prop so that's not the problem. The gears in the lower unit appear to be in great shape, The spline also looks fine. Also the boat is taking on water quickly I changed both bellows, water pump O ring and lower unit gasket also shift cable boot. Could the leak be related to the slipping? I heard it may be the engine coupler but I'm not for sure. Any Ideas would be greatly appreciated. thanks
