Hello,
I recently bought this boat...super clean and well kept in a garage. Last run 05. Lots of troubles getting it running with original tank. Squeeze bulb sucked down flat...engine barly ran.
Plugged in a remote O/B fuel tank and it perked up and ran great.
Still have the issue of fixing the big tank...pulled squeeze bulb off and applied air psi into tank and blew gas past the cap up in front of boat...then tried to pump from that same line and after 30 seconds the pumping slowed to a trickle. Seems something is blocking the fuel.
Q. IS THERE A SOCK ON THE LINE INSIDE OF THE FUEL TANK?? Tank just about full too.
(50 hp Johnson O/B 2cycle)
There is a access where the fuel sensor that I can get too but it looks too small to get my arm in tank let alone light to see...
Can any one help? To pull the tank, do I need to pull up the floor??
Thanks,
Tom Howell Mi.
Thanks,
Tom Howell Mi.
