ab59
Ensign
- May 10, 2017
- 982
Hello again , I have the deck ripped out and am taking the side panels off for recover but cant seem to find a way to remove the front of the flush mount side controller , a Teleflex or Seastar model that the shift handle is removed by a single bolt in the center of the bottom of the handle. It is connected to ( or was ) a 5.7 mercruiser . It is original equipment for the 1988 Starcraft ss20v Aluminum bow rider.
The problem is getting the front square plastic plate off , I can see what looks like plastic locks , maybe , inside with the handle removed. There is access to only one screw and when I loosen that it makes no difference , I really dont want to take the cables loose from behind unless absolutely necessary .
a little Help ??
a little Help ??
