1988 Winner Chameleon Fish/Ski Onboard Battery Charger?
cannon11b
I have a port on the front of my boat that is labeled "Charger or 12v ACC" but when I flip the cover up, I don't recognize the prongs on the inside....Does this mean my boat came from the factory with an on board charger? I can't seem to find the power source for it anywhere. Its a 3 battery system (12v or 24v) whatever that means. I've been using a portable charger and its been working fine but it is a pain to switch from battery to battery to battery all week to maintain charge. Is there a power cable I can plug into this port to charge all 3? Thanks
Jason Cannon
1988 Winner Chameleon 19 ft Fish/Ski
175hp outboard Merc
Lowrance Elite 7 Chirp
Grandad
I couldn't really see just what outlet you have, but I expect that it has a suitably sized wire and fuse protection that could supply a heavy appliance or you could back-feed it with a charger that will charge whichever battery the system is connected to at the time. Without knowing how your boat's wiring is laid out, it's a little hard to advise, especially with both12 and 24 volt available. I have a small 3.3 amp on-board charger/maintainer that is connected directly (via fuse) to my 12V electrical system. I have only 2 identical heavy duty deep cycle batteries with a battery switch that I can manually select to either battery at my whim. I alternate to ensure both are functional, fully charged and fully backed-up so to speak, as one is always waiting on standby. By securing the charger directly to the electrical system, I can select which battery gets the next charge when sitting as a trailer queen, but I don't have the 24V complication. - Grandad
EDIT - I just noticed, it's your first post. Welcome to Iboats!
cannon11b
Thanks for the reply, I'm learning the ropes slowly....thanks to youtube and all the forums out there! Iboats is the bomb
Grandad
There's a lot of guys that like to help. Here's my Winner Eliminator, circa 1975. - Grandad
