I'm trying to find out what size of prop I should be using for my 1989 30hp Johnson outboard it's on a 16ft aluminum fishing boat. Is any one able to help?
If you get us your present prop size (under the prop nut). And your wot rpm and gps speed.
along with your typical load and activities.
As Pootnic suggests a 12" should work but disregards your setup,load and activities.
