1989 50hp Force impeller
Gerald.Shepard
Engine rotates clockwise, is this impeller in the right position or should it be turned around?
jerryjerry05
That impeller is bad.
The vanes need to be straight/90d from the center.
It might pump water but not as good as it should.
They will orient themselves once they start turning.
But as they are in a permanent bend they just might fall apart when they start turning???
