First a little background. one of the piston rods came loose from the crank, lost needle bearing, and scored the cylinder. I took the engine apart honed the cylinder and installed a used piston and rings. I have 100 PSI compression on both cylinders. I removed the VRO and installed a regular fuel pump on the side of the motor block where a plug was and installed a plug where the VRO pulse tube connection was on the block. When I first tried to run the motor I found the top carburetor float stuck open and flooding the engine. I fixed this and cleaned both carbs and was able to get the motor running good on muffs.IT ran good at home so I thought it was good to go for a ride.
After starting the motor in the lake and moving the remote control to engage the prop the engine just bogs and dies. I can restart the motor and manually move the carb linkage to throttle the engine up and down and it revs fine.I have tried to adjust the idle screw a little more open and closed but nothing I've tried seems to work. My question is could the compression be too low for the motor not to run when the exhaust back pressure is higher in the lake? Or could there be a problem with the gasket between the motor and lower end? Or could there be an issue with high altitude 8000' and running stock jets? The boat worked fine before the engine sized so I don't think that's it. I have good spark so I think its a fuel issue.
So I guess my question is my motor compression too low for the motor to work in the lake?
