Okay guys here is what i have. i have tried to read up on it a ton before resorting to this and bothering you guys. 1989 force 125 1258f9b on a 1989 bayliner cobra. my dad bought it new in 1990. In about 2001 pulled the boat out for the year and it sat overnight and someone stole the lower unit. A shop here in portland, OR installed a new lower unit, heres the fun, supposedly it is a newer mercury lower unit that they said would work fine. Ever since then the boat would not stay warm if running at more than about 1/4 throttle. My dad parked the boat and sold it to my cosuin a few years later. First time he took it out he seized the engine. Bought a rebuilt powerhead and the boat is still doing the same thing, will warm up at idle but as soon as youre moving the temps drop way down below 100 degrees. Now i have the boat back from my cousin and trying to get it up and running correctly. Weve had the lower unit off and it does look like everything is the same as a force as far as i can tell from microfiche pictures. This is my first boat ive ever worked on so from all the reading i heard the only thing that cause an overcooling issue is the thermostat being stuck just wide open, definitely not my problem in this case. I have multiple 130 degree thermostats and have tried changing them out. I dont wanna buy a new force lower unit if that is not my problem, but thats where im leaning because this all started right after that lower unit swap. This is a very odd problem to me as i could find nothing about it happening to anyone else, any help would be much appreciated. Thanks guys
