theoldwizard1
- Feb 25, 2014
- 341
Re: 1989 Force 125hp outboard & its rookie owner
My point was, what are the tolerances from the factory on pistons ? If you get a piston that is 0.0005 over and the bore is 0.0005 under you could have an interference or at a least rings that are too tight.
You are correct. It the machine shops call on boring and what size pistons to order.NO! Let the shop "Mike " the cylinders first before buying pistons. Let them tell you how much the cylinders need to be bored then buy the correct sized pistons. The pistons are made in .010, .020, .030, and .040 oversized and are made to tolerances to provide correct clearance in an overbored cylinder. The machine shop bores to the correct size plus or minus about .0002 for tolerance.
