1989 force 50 HP tilt trouble
Rlightner
Was wondering if anyone could tell me what the band on top of tilt cylinder is called and where I can get one. Previous owner rigged it up and it leaks. The threads were stripped so he drilled it out and put a nut on backside but the little nipple of the fitting doesn’t line up with the
jerryjerry05
Called a banjo fitting, banjo bolt
F2A654983 $70
You might ask at Granger or maybe find it someplace cheaper.
Rlightner
Jerry when I look that part number up it says it’s for a 70-150 hp would that fit my 50 hp?
