1989 Force Tilt Unit Leaking Down
jim4045
My tilt unit is leaking down on my 1989 Force 85 unit. It leaks down until it hits the trim post and then does not leak down any further. Is there a rebuild kit or a way to fix this or am I going to have to replace the whole unit.<br /><br />Thanks Jim
clanton
Re: 1989 Force Tilt Unit Leaking Down
Try search, bump back to top if you cant what you need. The pilot check valve seals are the most likely cause.
