1989 Reinell 16 ft 3.0 L Cobra 4 cylinder Timing Chain Or Belt?
Codeman3014
Quick question, I have a 89 3.0 l Cobra engine Serial 302AMRMED . That the timing cover is leaking. If its a chain then im hoping its just the cover since there is suppose to have oil in it. If its a belt may be a crank shaft seal?. Either way there is a crack in the timing cover so it needs to be replace. Anyone know where i can get one and if its a Chain or belt?
Don S
Re: 1989 Reinell 16 ft 3.0 L Cobra 4 cylinder Timing Chain Or Belt?
neither, it's two gears.
