i_build
- Apr 24, 2005
- 164
I ran a can of spray decarb through the carbs while running the engine, the directions ask that the engine then be shut off and started again after a period of sitting. When I started the engine it began to miss "hard" I imediately shut it off, and restarted it and it ran fine. <br /><br />It ran fine for a few all day trips, but now it started missing as it did during the decarb consistently. It starts missing at about 2500-3000 rpms which is not enough for me to plane. The weird thing is that if I shut the engine off, and start it and IMMEDIATELY got to WOT, it almost gets up to about 4500 rpms at a plane and then starts to miss dropping back down. Otherwise if I let the engine idle for a few seconds after starting then try to throttle up, it only gets to 2500 - 3000 rpms (without getting on a plane). I'm guessing fuel related, but I am open to suggestions / recommended tests. Thanks.<br /><br />
