1990 225 sundowner ?
82plumber
This is my first boat and I'm trying to find the location of the front bilge pump, the location of the trough hull transducer for the depth finder and last what a small round button does. The button is located above the key to the left of the horn button and is not the safety lanure.
Thanks for the help in advance
DBreskin
Re: 1990 225 sundowner ?
I'd be surprised if there WAS a front bilge pump. I expect the whole bilge should drain to the rear. If it's not, perhaps the drain passage is blocked.
My 1992 boat has the depth transducer located about 3 feet from the stern and about 6 inches starboard of the keel. It's easy to see from the bottom of the boat.
The small button is probably a circuit breaker reset; at least it is on my boat.
Have you tried downloading the specifications and brochure from the Four Winns website?
82plumber
I will crawl under the boat and look for the transducer. And circuit break makes since. Thanks for the help. Now just bilge location and i will be good
Lou C
My 88 H-200 has some kind of transducer glued to the inside of the hull in front of the engine on the starboard side. It has been disconnected for years, I use a transom mount depth finder....
