1990 4.3l shift cable replacement
boatman40
I removed the alpha 1 out drive. took the cable loos from the engine, unscrewed it from the out drive,I cand get it to pull through the transom. What is stopping it? Then engine is in the boat.<br />What do I need to do to replaced the cable. The boot was bad the boat leaked so I was told to replace the shift cable also. I didn't relise the trouble.
jeff13601
Re: 1990 4.3l shift cable replacement
It must be catching on something in the motor compartment. I just cut mine and pulled it through.
Bt Doctur
did you remove the white plastic spiral wrap.cable wont come out if it was left on.<br />Ed
