1990 bay 16' 50 hp force 3blade 11 1/2 pitch ?
fulleone
i have a 3 blade 11 1/2 pitch if i go to a 13 1/2 will i get less over rev and a better plain:
Frank Acampora
Re: 1990 bay 16' 50 hp force 3blade 11 1/2 pitch ?
Without full information such as current RPM and current problem it is difficult to say. However, I can give you some general tips. On a 16 foot boat, going up in pitch will lower the RPM possibly by 400. The 13 1/2 pitch prop MAY load down the engine so that your top speed will actually be lower and the hole shot or time to plane will take longer. If you can get one cheap, it is worth experimenting, but if you need to buy new, then it would be best to try and borrow a demo prop to test before you buy.
I did have a 15 foot Glastron that was actually 15' 9" and with an old Chrysler 55, I was turning a 10 3/8 X 13 1/2 prop at 5500 RPM with a top speed of about 27-28 MPH, so I don't think a 13 1/2 prop on your bayliner is out of the question. Just don't expect to pull a water skier well with it. When I had four people in the boat, it was necessary to drop back to the 11 1/2 pitch prop.
junior1113
lower # on pitch will increase rpm and wil be faster plane but need to be in range of recommended rpm at wide open throttle
fulleone
thanks for the info ill try a couple things befor i buy a new prop
fulleone
ok my current rpm is about 5300 full throttle by hand held rpm meter i was told i can buy a plain kit that bolts on the lower unit that will help plain it faster with out changeing my prop and if i changed the prop later to a four blade same pitch ill get more torque for pulling is that true
