1990 Doral Cavalier Specs? Owners manual? Want to buy a new prop need help!!!
adamnigro
I have a 1990 Doral Cavalier with a 5.7 in it, I have the manual for the drive in it, but would like a manual on the actual boat. I am wanting to put a new prop on it and even after looking at several prop selectors, am confused as to which one to put on it? Any Cavalier help at all would be great!!
I don't have a cavalier but your best bet is to solicit from these posts what is the best prop to use (ie pitch and diameter) as there is lots of experience on here with respect to prop selection... you will also need the outdrive specifics.. (Mercruiser alpha one or omc cobra, king cobra). Any marine dealer can go from there to help you select a prop that will fit on your drive and have your boat perform as it should.
jbcurt00
You arent likely to find a manual for the boat, not like cars. Manuals were very basic and not boat specific.
adamnigro
Thanks guys now I can't get my water to the sink, the pump runs but maybe I need to prime it or something??? Always worked before.....maybe leave pump running?
