Re: 1990 Evinrude 140
A 1990 model will have the primer solenoid system. As long as the system is functional, try this starting procedure:<br /><br />Pump up the primer bulb till firm. Turn the key "on" and push it in AND hold it in while cranking. Release the key when ther engine starts (of course - LOL!).<br /><br />To verify the primer functions, remove the engine cover and have a friend turn the key on (don't try to start) and push the key in several time while you listen for it's operation - it'll click each time the key is pushed in. I believe the primer solenoid is located below the VRO pump on that engine.<br /><br />If you gave us the correct model year, this unit also incorporates QuickStart. Q/S electronically advance timing 10 degrees every time the engine is started. You should have a high idle speed (maybe 900-1000 rpms) until the engine comes up to temp, then rpm drops to normal. Is Q/S functioning??<br /><br />-John
