CumminsChris
- Jun 14, 2015
- 13
Hi guys, I just recently bought a 1990 Bayliner with the 120HP Force L-drive and was wondering if you all could me with some issues. The boat runs decent on the muffs, idles fine, revs fine, but will occasionally die at idle if you run it long enough. However when you get it in the water it dies frequently at idle, getting into gear and moving is hard. If you manage to get it in gear and above idle without killing it you are golden, it will run all day at any RPM but idle. It is a real pain to launch and load because it will just die on you and drift around while you are trying in vain to get it restarted.
Restarting is no walk in the park, because it also has a weird quirk where after it dies, it often won't crank over fast enough to start, it's like all of a sudden the battery is really weak, or the compression of the motor tripled. If you mess with it long enough, you can get it to crank over and try restart it, but by then then it's usually flooded. Starter and all wiring from battery to starter is brand new.
Normally I would attribute the idle issue to tuning and the not wanting to crank as a weird quirk, but then I pulled the spark plugs as part of my troubleshooting and found the top 3 were slightly carbon coated with black soot, nothing major, but the bottom one was clean enough to eat off, didn't have the fuel/oil sheen of the other plugs, and had water droplets beaded on the threads. Now there is no way the engine isn't firing on all cylinders when cruising, it runs great, sounds smooth and has plenty of power. It just HAS to be firing, but after finding the plug clean like that and evidence of water, I am very suspicious of how that might relate to my other problems. Could you more experienced fellows shine any light on this for me before I go do drastic things like pull the motor? I'll put a pic of the plugs below, thanks for any help!
