victordzhur
- Jul 24, 2013
- 10
Hi I have recently bought a boat from my brother in law. It has a force motor. Last time he used was two years ago and then it sat on his yard. So, he moved to Canada and I got a boat. I have tried to crank it up, put mugs on, got battery in, and nothing. I checked spark its there, but when I checked compression it was 120 top 105 second about 20 third and last had virtually no compression. That raised concerns, I read a little and decided to pull head. It came off fairly easy, head bolts weren't super tight like you would expect. ALL cylinders wiggle a little bit but the bottom one looks and wiggles the worst, additionally upon closer inspection there are some minor scratches like when aluminum piston rubs against a sleeve. Ill try to post some pictures. Does any one have any suggestion on what to do next. I wanted to do all work myself. Please help.the motor is 1208F90B
