1990 Force 50 horse runs ok untill the engine warms up.
Engine runs about 5 mins and at this point we lose the top end(high rpm and speed), it also will not idle, it dies when you try to idle it. Like running half speed with no idle.
Also appears to misfire at times.
If you shut the engine off and allow it to cool down (5-10 mins) it will run.Then we start the entire process over again after running for about 5 mins.
Previous repair history in last year( head gakset, water pump, thermostat, spark plugs, temp sensor, rebuilt carb, removed all old fuel and installed new)
Any ideas?
Any and all help is appreciated!
Any ideas?
