1990 Force 90 control cables
amcervantes
Hey guys I'm new to the forum and I'm looking for some help. I have a 88 17" Lund. The Johnson 70 ate the #3 piston and shop wanted what would of been equal to a remaned motor. I picked up a good running 1990 Force 90 with controls Model 906x90c. My only problem I have at the moment is finding the shift cables for the control box to engine. It looks like the ends that go on the motor clip on. Also is there a diagram for hooking up the cables. Ive been searching for a few hours and haven't found what I was looking for. Any help is appreciated.
amcervantes
Sorry about not specifying. It came with a U.S. marine control with trim and tilt and wiring just no the cables. Its actually that same exact one on ebay.
jerryjerry05
The cable just a base Morse 3300 or 33
Just make sure they are long enough.
​Measure from the shifter location and around the transom to the center of the motor and add 4 ft.
So if it's 15 ft. from the shifter following the bends and turns.
​You add 4ft .
​That makes it 19ft.
You have the cable connectors?
The shifter is different than the connectors on the motor.
​Google: force outboard cable connectors.
There are 3 different ones.
You'll need a short one and one with the spring loaded connector.
amcervantes
Thank you so much! I've been searching for 3 days and those cables and connectors are exactly what I need.
jerryjerry05
Too short is a BIG problem.
​Too long not a problem(unless it's 15ft to big or longer.
I ordered cables for my boat.
They came and I had a friend trying to install them.
They sent the wrong ones.About 5 ft.too long.
The excess cable can make the shifting a bit harder the older the cables get.
​Too short and they can actually pull the throttle back when you turn and can make the clutch dog go bad.
So longer is better, but not too long.
