Hello,
I have a 1990 18' Bayliner Capri with a 1990 Force (by U.S. Marine) 90 HP outboard. The last two weekends I have had some problems and I was hoping to get some input.
Two weeks ago I had the boat out tubing. We dropped in the water and ran about 12-15 miles from the dock the the tubing spot. The boat started like it always does (a couple turns choked then a turn of the key and starts right up) and we had no problems running WOT to our tubing spot. Had no problems tubing 5 or 6 runs with shutting the engine off each time then starting right back up. Then the problem started....after about the 6th time of shutting the engine off I could not get the boat to start up again. Then it drained my battery completely....dead in the water. Had to wait for a tow back to the dock. I figured that I drained my battery faster than it could get recharged. So getting home I plugged it into my trickle charger and kept it topped off the whole week. I have a deep cycle marine battery by the way. So then this past weekend I was set to go out fishing, but wanted to make sure that I wasn't going to have any issues before getting on the water so I hooked up the earmuffs and it started on the first turn of the key. I let it run idle for about 10 minutes and figured that I was fine.....BIG mistake. Got stuck on the water again waiting for another tow! This time the boat took a little bit more time than normal to start, but once we started running it was fine. The fishing spot was about 30-40 minutes from the dock. Once we arrived at the fishing spot I did not even have it back in neutral before it shut off. Again, I could not get it to start. Again, began to sound like battery was drained.
When I say that I could not get it to start I mean that the starter engages and turns the flywheel, but it will just not turn over. This happens repeatedly until the the starter begins to drain the battery.
I have a couple of thoughts.....
1. My battery may be faulty (even though it is only two years old and was stored indoor last winter)
or
2. My battery is not being charged when I am running. I checked my connections to me rectifier last night and there was a connection that was slightly loose. Could this have caused the engine to have problems while running or would this just cause problems with charging the battery alone? I will hook it up tonight and see what my voltage is when I am running (if I can get it running.
I would appreciate any input!
Thanks
or
Thanks
