1990 Force 90 hp power tilt bleeds off
Yotafied
Power tilt works great going up, smooth quiet but wont hold in place. Like cylinders are bypassing. No leaks. Model # 908F90C. Easiest to Replace or rebuild cylinders? Thanks Ed
DunbarLtd
If I had to guess Id say it is the seals inside the valve body of the tilt/trim motor. The valve body is the bottom part where all the lines screw into. There are rubber seals in there that fail.
There is a sticky on the front page of these forums that shows how to remove the valve body and replace the seals. I had the same problem and the repair fixed it for 3 years now.
When you do the repair you should replace the oil in the reservoir. Suck out all the old stuff as much as you can and replace.
There are posts on here that explain how to do it if you search for it. You can add too much oil if you do it wrong and push oil up into the motor so make sure you refill properly. Good luck.
Yotafied
Thank you. Can you post the links you are refering to? Im new to iboats and not having any luck finding the sticky or other posts about it. Guessing Im not wording it right on the searches
DunbarLtd
When you click on Force forums they are at the top in yellow.
jerryjerry05
Be real careful when dismantling the 2 check valves.
You can destroy them easily.
Too much heat can ruin the springs.
Sometimes(most times) they can be a real MF to get out of the housing.
1/8th inch pipe plugs (3) and a compressor can help a lot.
